Speedfan and 680i
kevineugenius
I have a 680i mobo, Evga, with my 120mm rear case fan, northbridge fan, and CPU fan all attached to headers on the motherboard. It runs pretty warm, so I installed Speedfan. SF gives me the temps, but only shows any readings on the CPU fan. Is there another program I should get or what can I do? I'd really like to have some sort of monitor on the exhaust and northbridge fans, as well as CPU temps.
I doubt this exists, but are there any ways of monitoring GPU temps? I don't know that they even have sensors built-in, let alone that they send that info to the mobo at all.
You can use RivaTuner or Everest to monitor your GPU temperature/fan speed/etc. The northbridge fan always runs at 100% (5000rpm, IIRC), and your case fan should show up in the BIOS and AFAIK there aren't many 120mm fans that have adjustable speeds via software.
If it shows up in BIOS, what would be keeping it from showing in speedfan though? I've decided to not care... carefree gaming until something burns up will be more fun than stressed-out-about-heat gaming and spending $450 on water cooling for SLI'd 8800gtx.
