Hi there, probably been asked before but the search isnt working. Could someone tell me if the Thermalright SP-94 will fit on an IC7 ok? The TR site only mentions IC7-G and Max3
Also, i have been trying to figure out what the best orientation is for the HS unit. There are alot of conflicting views to get the heat pipes to work efficiently, am i locked into one orientation with the IC7.. or can you change it ?
Thanks very much
Thanks very much
