So I'm at the local GoodWill the other day and I see an old console radio (kinda like this one, but much less ugly). I picked it up for cheap to mod into an mp3 server. Basic idea is that instead of hiding the mp3 server in a corner and running it to something else, why not make it a centerpiece unto itself.
I have most of the computer pieces here already (scavenged from my heap), aside from an M-Audio Revo for the pc, but wanted some input on a few points. The built in speakers are utter crap. I plan on pulling the guts out of the sides and replacing them.
1. Should I build my own custom speakers/boxes to mount into the space, or should I buy something prebuilt that is about the right size and mod them into the space available?
2. If I do the former, how would I go about building speaker cabinets and what is good to drive them, or should I not try, and just buy some to put in (in that case, what would you all suggest)?
3. In either event, what should I use (receiver or otherwise) to drive the built in speakers? Keep in mind that this is just going to be used for music, not movies or anything, so I would think that 2.1 is the most I am going to need.
Things to consider:
- I am on a budget, so price is important.
- I want to keep the unit as self contained as possible (will mod a 15" lcd, touchpad and keyboard into the top compartment for I/O).
- Aside from some new paint, and new fabric to cover the speakers, I want to keep the unit looking stock.
Things to consider:
