Sonata wire arrangements
ctbook
I have the Sonata with a A7n8x-E Dlx mobo and a AIW 9800 Pro. I'm trying to get the case and wires and cables and stuff squared away as its a mess now. I want to get my temp down.
Anyone got any pics?
Thanks,
ct
Reverse hdds. Stuff wires behind mobo tray and drivecages. Run gfx card wire through screwhole in mobo. Thats about it.
Ditto. I have used the Antec SLK-3700BQE, which is the same case minus the bling, for numerous system builds and that's how I wired them all.
Wow! Cedar Rapids! I grew up there! Graduated HS in 1988. 25 years in The City Of Five Seasons.
Please tell me if you could, what is meant by reverse hard drives?
He means when you install your hard drives into their removeable tray thingos, put them with the cables to the back. There is a large enough hole on the other side (when you remove the right side panel) to wire them up without any dramas. There are holes (slots really) in the drive cage to pass cables through.
