fasterthanlight
- Nov 22, 2005
I have bee on firefold.com looking at racks, and I don't know what to purchase. I am completely remodeling my basement and plan to install a 24 port patch panel in the rack. I will have a switch, router, and cable modem. The modem, router and switch will stand up vertical. All are about 6 inches high. I can build a cabinet out of wood to hold the rack frame. since it is in the basement, I don't think it is a good idea to leave it completely open (moisture and bugs). Is there a size (U)? that I should get? How deep? Give me all advice you can.
Anyone using the Leviton SMC system?
