- Feb 16, 2003
Just finished piecing my kit together at frozencpu (their prices seem a bit high.. but what do I know)
Firstly, tubing. I'm looking at going 1/2" ID x 3/4" OD, is this a decent size or way too thick?
Phobya G-Changer 420mm Radiator - Black (35196) Gonna try to fit fans on the bottom for push pull, certain motherboards can't do push pull on 60mm rads in the 810 though.. and I dunno if the P8Z68 will have the clearance
XSPC RayStorm High Performance Acetal CPU Liquid Cooling Block - Intel (Sockets LGA 775 / 1155 / 1156 / 1366 / 2011)
Alphacool Ultra Pure Water - 1000mL x 2
Alphacool Repack Single 5.25" Acrylic Reservoir - Clear - Dual DC-LT (15166) with Alphacool DC-LT 12V DC Pump
Danger Den DreamFlex Value Pack - Tubing / Clamps / Tube Cutter ( 1/2"ID x 3/4"OD ) - UV Blue
$363.83 before shipping
Going compression fittings on all parts
Reason I'm getting a large rad is that I plan on adding GPU blocks (probably SLI setup) later on
If you could give me advice on the parts I've chosen, if it's a good setup for what I plan on running (i7 2600k, eventually two cards)
Is the Res too small, should I get a dual bay?
