I have not been paying attention to computer hardware for about four years now. I have been asked to put together some kind of mid-range PC (~$750, no monitor or peripherals). I did a bit of research myself but I'm still not completely caught up. My questions are...
1) Ivy bridge vs Haswell future upgrade options. These use different sockets from what I have read. What are the upgrade options when new mobos and CPUs come out? I've heard this happens in the fall? Are both lineups dead?
2) Sandy Bridge / Ivy Bridge / Haswell started to have built-in GPUs, correct (on-die? not sure about the correct choice of words)? Seems like a pretty big waste if the plan is to get a mid-range graphics card for some gaming. Are there benefits of such configuration? Or is it best to disable the built-in GPU? Is that even doable?
3) Not planning on having the CPU overclocked. However, out of curiosity, I remember when Sandy Bridge (or Ivy Bridge?) came out there was some outcry that CPUs won't be able to be overclocked. Is that the case? How are CPUs overclocked now? Changing the multiplier?
4) K vs non-K CPU, probably related to the last question. I see that there are minor differences between the two, like higher turbo. Is this also overclocking related (unlocked multiplier)?
5) On Haswell, I see that almost all high-end CPUs have HD 4600, with a single having Iris Pro 5200. Is this only about performance, or are there other considerations?
6) Audio over HDMI. Is this doable with these integrated GPUs? Actually, I don't even know if this is doable with "normal" graphics cards.
