intogamer said:how do you properly solder something....
it just won't melt.... the iron is so hot that is becomes brown =( a bit
intogamer said:soldering a wire wrapped with plastic to a strip
soldering wire to laptop backlight
Riveninside said:
Did you damage the component you're soldering with all that heat?intogamer said:I soldered it before for like a minute...
eyedol said:For the visual learners
http://radiojove.gsfc.nasa.gov/elab/soldering.htm
Part of the problem is probably the equipment. If you have a good quality solder like kester you shouldn't have any problems with the solder sticking and flowing nicely.
Talonz said:You are using solder right?
