G'ßöö said:it comes with paste. I've read the temp issue but don't seem to have them myself, however, that's instereting why [H]'s review didn't address it as so many gripe about it. and why not benching it vs the MSI NEO for better headlines?
I made it a merry halloween![]()
G'ßöö said:I thought I'd paste in the best part of that sudhian thread about the temp issues for anyone else who doesn't have the whole day at work to read it. Odie says:
"Actually, its NEWER 939pin Athlon64's that are affected by this issue. Basically, AMD has changed their thermal monitoring spec mid-production. This is why none of the SN95G5 reviews are finding this issue, because AMD samples the reviewers with the same processors they sample motherboard manufacturers to ensure compatibility. Thats why the problem is not unique to the SN95G5, many motherboards for the 939pin processors were designed when only the 'single current sourcing' processors were available. AMD has now moved to 'dual current sourcing' in newer processors. Its hard for us to say when exactly the change was made, AMD has not been particularily helpful on this issue.
Now that we have one of these newer production processors, we're in a better position to develop a work-around. "
[BB] Rick James said:New meaning like the production of the 4000 and the FX 55's or just newer as in it doens't matter what chip just as long as it was recently in production?
Anyone know the production dates of the chips that Monarch has in stock? I just bought one today.
DarkWind said:Without looking at the code on the CPU die itself, there is no way of knowing.
to add: placing the ice system on is tricking people. take it slow and refit it a few times if need be. but testing the temps right after is crutial or you could end up with high temps and smartfan might not work correctlyDarkWind said:Take it slow, read the instructions and double check everything and you'll be fine
Make sure to put on the correct amound of thermal compound on the CPU die. If your not sure on the amount, put a small rice sized grain on the die, spread it out with a small flat edge object and then apply the ICE system. Take it back off and see if it covers the entire surface. If not, wipe off the old compound with rubbing alchohol and cotton swabs and try again..etc etc etc...
