I built my new rig last night, but I'm curious to know what kind of temps I should be expecting. Check out my sig for all the system specs. The bios indicated that the CPU temp was around 52C and the System was about 50C. This was with no air conditioning on at the time, so the room was already hot to begin with. These temps were also taken immediately after Windows XP Pro install. The windows install and the driver installs all ran smoothly, so the system is stable. I am just not sure what I should be expecting. I applied a thin coat of some old Artic Silver 3, so I believe everything should be good.
Can anyone who has a similar system check their temperatures in the bios and let me know how theirs compare?
Thanks.
Thanks.
