SMP help....missing-work-files
magoo
Well.......
loaded SMP on new box.
e4300 at stock, board wont allow OC (cheap ASUS)
running under windows XP home
ran 2601 500,000 frames......start time 1050SAT 5 MAY,STOP 2200 7MAY
box ran disconnected from internet
when finished it said.....missing_work_files.
I left it alone and connected
finally at 0200 this morning it unloaded and gave me all of 206 points.....WTF????
any suggestions, new work unit started this AM by the way.
thanks, magoo
Well.......
thanks, magoo
This is a error. I suggest you reinstall the FAH client and rerun Install.bat to make sure all works fine.
So in other words.......delete the current SMP client program (F@H)
reload the program
start again
bummer.
reload the program
start again
bummer.
Yes but don't forget the Install.bat before restarting ;)
Thanks......could that completed work be stored somewhere, before I dump the program???????
If you have a completed work waiting to be sent, use fah -queueinfo to find the work # then use fah -send #. However, if it is a incomplete work unit, it's a bit harder to keep it without getting corrupted but you can try to backup the work folder and queue.dat.
Thanks again.
I redownloaded the net 2.0 and the SMP client.
When I opened it this time it was very smooth compared to the last one.
Seems to be churning away happily on 2610.
Unfortunately I lost an entire WU:(
We'll see tomorrow when the WU finishes and is ready to send.
Thanks again.
I hope for you as well :)
From my extensive SMP borging experience, I can say than 1 of 6 installs get screwy one way or other even if I religiously do the same steps. That's the stupid nature of the beta software :rolleyes:
