I'm trying to move mys system from a massive antec 1080AMG into a smaller and lighter case that I can easily take with me to northwern California (to Stanford) and back for breaks (I live in Ohio). So far I've come up with these tenuous truths:
-Although a SFF would be nice, I'm kind of on a budget and I can't find a SFF that would maintain my current overclock without modding at a cool temperature. I've already got the DFI NF2 board...it's a nice board, and I'd like to keep using it...so whatever case I get would need to support its ATX form factor.
-I've got the existing 430 watt PS from 1080AMG...so the case coming with a power supply is unnecessary.
-I don't want my roommate to hate my computer...this means gaudy lights and loud noise are a no-no. It needs to be on all the time (even while sleeping).
-I'm going to be flying to and fro...I don't want to check my case because those bastards will drop and kick it. I know from experience you CAN take a case carry-on, you just need to make sure you get an overhead bin for it. So it needs to be as small/light as possible for travel... I'd like to take it with me on breaks.
-Price is a constraint...I'd say nothing more than 130.
My thoughts:
I don't care if its a desktop or tower as long as it fits into the above criteria. I've looked at the Coolermaster Cavalier desktop cases, but they're not exactly small. I've also looked at the Super Lanboy. I'd hafta disable the front lighted fan. I'm not a big fan of the front bezel, it looks silly to me, but I'd go with it if it was the best idea. If you would recommend this case to me would you also kindly recommend some replacement fans or air filter material?
I've always trusted hardforum to unconfuse and clarify my perception based on the current computer component scene and you guys have never let me down. Anything you've got I'd appreciate. I'm sure I'm not the first person to be in this situation.
My thoughts:
