Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm looking for a small cube, or almost cube, air cooled ATX case.
It will be used to house a SOHO/family use Windows 7 Pro pc.
I haven't had much luck finding anything good.
Any ideas?
Thanks.
Hugger
...the smallest decent ATX I'm aware of is the Antec NSK4000/4480/4482 series of cases.
I'm planning to mod one of these soon, which is beside the point, but my research to-date indicates it's probably the smallest high quality ATX around at 42x42x20cm.
