Switches will automatically "switch" to 100mbps or even 10mbps mode if they detect non gigabit devices attached to it, and that port will become that speed. All the rest will remain the same, you just simply won't get gigabit speeds on that particular device, nothing more.
This.
Only the port with the 360 on it should come down to 100mbps.
If you're not getting Gig speeds, my question is are you sure your switch is Gig?
Many home-level routers (if that's your switch) aren't Gig.
And I'd also hope you aren't trying to test it downloading something over the internet. Without shelling out some huge money I don't know of anyone that would have 1000mbps download speeds at their house
Also keep in mind there *are* overheads. IIRC it's something like 40%... So you'll never see a file transfer that's running at 1000mbps/sec.
Also it may be the NIC configuration in your computers that are affecting it.
The DIR-655 is still a great choice - just make sure to buy it locally so, if you have any problems with it, you can return it for another.Is the DIR-655 still a good choice or is there something newer at that price point that is better? And how about ~12-port switches?
I cant recall what switch I was reading about, but it was a gigabit that if a 10/100 device was plugged in, it would slow down all the ports to the slowest speed. Just like with your Xbox 100mb would make the switch step down to 100mb.
If that really exists, then its a worthless POS.
