I have two gigabit enabled machines. They each have different motherboards, but both motherboards use the Realtek RTL8111D NIC. The machines are connected in this way:
machine 1
~15 feet of CAT6
D-Link DGL-4300 gigabit router
3 feet of CAT6
in-wall coupler rated for CAT5e
~50 feet of CAT5e
Rosewill gigabit switch
~15 feet of CAT6
machine 2
File transfers between the machines are slow.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I downloaded the PCATTP tool:
http://www.pcausa.com/Utilities/pcattcp.htm
On one machine I run:
pcattcp -R 99999999
One the other I run:
pcattcp -t -f M 192.168.0.4
I see a speed of ~11MB/s (megabytes/second). If I run the second command on the same machine as the first (loopback), then I see 500MB/s.
To try to simplify the test, I replaced the Rosewill switch with a CAT5e inline coupler. I still see only ~11MB/s.
There shouldn't be a problem mixing CAT5e and CAT6, and both can do gigabit.
Do you think a cable or coupler is damaged? Should I get a tester tool? It seems if there was a bad connection or damaged cable that the connection would be reliable. I use the internet through machine 2 every day and it is fine.
Does anyone have any ideas on how to fix my slow transfer speeds? Both machines are running Windows 7 Ultimate, and both have Intel X25-M SSDs. I have set both NICs to 1gbps full duplex. Are there any other settings I should look at? Anything at all that could help?
machine 1
~15 feet of CAT6
3 feet of CAT6
~50 feet of CAT5e
~15 feet of CAT6
machine 2
pcattcp -R 99999999
