So I just bought a gigabit switch and a gigabit file server for work and I am having incredible difficulty getting it to run at it's full potential. Here is my current set up:
4 x PCs connceted to a gigabit 16 port netgear unmanaged switch (Only 3 of these PCs have gigabit network adapters)
1 x 10/100mb ADSL modem router connected to swtich
3 x Printers / MFC connected to the switch
1 x Synology DS-209j being used as a file server connected to the switch
So, the issue is that the file transfer speeds between the file server or PC's connected with the gigabit network adapters are only getting a network utilization of about %12.5 or 10mbps.
The network connections display connected as "1.0 gbps" but am still getting 100mb transfer speeds.
Since the modem only has 10/100mb and is currently being used as a DHCP server, is all the network traffic being filtered through the router and creating a bottleneck?
The DHCP settings for the modem are set to auto. If I disable DHCP on the router and manually set up static IPs on each device, will that solve the slow network speed or is this problem not related to the modem?
