Ok I recently installed a SLK 900A heatsink to cool my XP 2700. Now I haven't installed a tornado on it, just an Antec Fan rated at 33 cfm that I bought from best buy. My computer runs fairly quiet with just a soft hum from the 5 80 mm fans, and a 120 mm fan that is inside the case blowing cool air onto my vid card.
Now my question is wether or not my temps seem normal.
Ambient Temp: 65 F 18.33 C
Case Temp Idle: 77F 25 C Diff = 12F 7C
CPU Temp Idle: 95F 35C DIff = 30F 16.66C
Case Temp Load: 86F 30C Diff = 21F 11.66C
CPU Temp Load: 118F 48C Diff = 53F 29.66C
Note this is using a 80mm*25mm Antec fan mounted on a SLK 900A. Temps taken using MBM5 and load temps while priming turture test #2. Also one of my 80mm exhaust fans has been running consistenly slow for some reason (I think it is dieing, and I have already purchased a new one). Also I used the thermal compound that came with the heatsink.
Are those temps ok?? What can I do to improve them??
Thx
Thx
