Has anyone used the Autostreamer to slipstream their windows disk with SP2, and if so when you did the install with it did you seem to get an awful lot of errors or conflicts.
The problem I have is when I try and use my original win-xp pro disc without SP2 it gives me a blue screen when trying to install it. Says something about pci.sys error.
Looked it up pci-express is only supported in sp2 versions of windows, but I am wondering if the slipstream is causing some files to be corrupted upon install.
If anybody has had similar issues let me know, so I know I am not crazy!
