Slinky Supercomputer
babochee
If you haven't seen this its worth a watch. Going for $15,000 on ebay ATM...
http://www.dailymotion.com/video/x14vf5p_dream-machine-fastest-24-7-rig-on-earth_videogames?start=1
DMARK Fire Strike Extreme HALL OF FAME RANK #5 http://www.3dmark.com/hall-of-fame-2/fire+strike+3dmark+score+extreme+preset/version+1.1
3DMARK Fire Strike HALL OF FAME RANK #5 http://www.3dmark.com/hall-of-fame-2/fire+strike+3dmark+score+performance+preset/version+1.1
Geekbench3, http://browser.primatelabs.com/geekbench3/5168
MemTweakIt Global Leaderboard Rank 10-17 (Veniamin Score 134754) http://rog.asus.com/rog-pro/memtweakit/?model=ASUSTeK COMPUTER INC. RAMPAGE IV EXTREME
SLINKY SUPERCOMPUTER 5.15 GHz, 88 Lbs (40KG) of Luxury Hardware.
Slinky Supercomputer 2013/Q3, System Specs:
External Water Cooling System;
Aquacomputer Aquaduct 720 XT Mark V Ceramic
Customized Case;
BitFenix Shinobi XL Extreme Watercooled Edition Performance Gaming Chassis
Red lights exterior and UV lights interior
2 x LED Fan - 230mm - Red/Blue
1 x LED Fan - 140mm - Blue/Red/Green/White
4 x LED Fan - 120mm - Blue/Red/Green/White
3 x LED Fan - 120mm - Blue/Red
Highest Performance Radiator XSPC AX360 Triple-Fan
Highest Performance Radiator Phobya XTREME 200
Highest Performance Radiator Black Ice® GTS Gen Two Stealth 140
Reservoir Koolance TNK-501 Single 5.25" Bay
Reservoir Phobya Balancer 250
Reservoir Phobya Balancer 150
Designs Infinite Pumps Bracket Vertical Version Black
2 x XSPC Premium Laing Double DDC Clear Acrylic Top
4 x Laing DDC 3.25 pump 12V
Motherboard, PSU, CPU, GPU, RAM, HDD & SSD;
ASUS Rampage IV Extreme, SLI & X-Fire, SATA3, USB 3.0, Bluetooth, GB LAN, PCI-Express
Power Supply 1500W Cooler Master Silent Pro M2
Intel Core i7-4960X Ivy Bridge-E
4 x EVGA NVIDIA GeForce GTX TITAN 6GB
4 x EK-FC Titan Backplate - Black
32GB Corsair Dominator Platinum High Performance (PC3 2400MHz) Cas Latency:
2 x Samsung 840 PRO 512GB in Raid 0 ~ Primary hard disk
3+2TB on HHD
Innovation Cooling Diamond "24 Carat" Thermal Compound (only)
Water Blocks for Motherboard, CPU, GPU, RAM;
EK-FB KIT RE4 - Nickel CSQ Rampage IV Extreme
Aquacomputer Cuplex Kryos XT Series - .925 Silver Edition - Socket LGA 2011
4 x EK Geforce GTX Titan VGA Liquid Cooling Block - Nickel (EK-FC Titan - Nickel)
8 x Koolance RAM-33 Water Blocks (run liquid along both sides of every DDR3 )
Tubing Fittings & Connectors;
Clear UV TUBING and Not-Conductive Fluid UV Green Clear
8 x Koolance QD2 Quick Disconnect No-Spill Coupling Male, Threaded G 1/4
8 x Koolance QD2 Quick Disconnect No-Spill Coupling, Female Compression
6 x Koolance Sliding 180-Degree "U" Connector;
10 x Koolance Nozzle Single, 1/4;
10 x Koolance Nozzle Single, Swivel Angled 1/4
3 x Koolance Nozzle Coupling adapter Male-Male
3 X Koolance Dual VID Connector
Operating Systems: Windows 8 Pro 64-bid
System components rate
Processor 8.8
Memory (RAM) 8.8
Graphics 8.4
Gaming graphics 8.4
Primary hard disk 8.4
The Hardware cost $13,000+ in US
Pfft, ha, he used Samsung SSDs instead of enterprise-grade Intel DC S3700 800GB SSDs with a real hardware RAID card *and* using one of those drives as SSD cache upon SSD storage *and* maxed out RAID card DRAM *and* watercooled RAID card.
Shoot, he even forgot to get a 4000w 3U UPS. He should have also thrown in there a 5-drive RAID6 using 4TB Enterprise-grade HDDs. He'd have the storage backed up by enterprise-grade Intel SSD cache + be able to lose 2 drives and still live + have 100% chance of calculated recoverability. Should also throw in a separate unit with multiple 4TB drives in a RAID1z3 (or whatever).
Enterprise-grade massive storage in RAID6 with enterprise-grade SSD performance, check.
OS drive with enterprise-grade SSDs in RAID10, check. (Would be total of like 5x 800GB Intel DC S3700 SSDs -- one of them to be used as cache)
Expensive RAID card with water cooling fitting, maxed out RAM, SSD cache module, check. (Card needs to support at least 10x SAS connections)
Huge UPS for clean power, regulated voltage, continuous uptime for at least 30 minutes at max load (4000W UPS might not be enough actually?), check.
I would personally also put that machine on a clothes washing machine rubber mat folded in half (double layer) for vibration reduction, and use rubber face covers for any fans to assist in additional vibration reduction.
EDIT: Still missing a high-end dedicated audio card, network card (perhaps enterprise-grade with multiple interfaces?), and a beefy wireless card that could be excellent for wardriving and radio haxing.
EDIT2: Then need a white van and some magnetic rails / one of those rugged portable server racks. If you can fit all this in a van, and have several different antennas available to be connected to the machine, then this is wicked. Also, need several PS2s to assist in more complicated password cracking.
Agreed.
