Slight Problem
ND40oz
I'm not uploading any results, all of my boxes appear to be sitting there without any results being uploaded? I can ping the Standford server and I don't believe we made any networking changes yesterday, what should I begin looking for to troubleshoot?
Most of my boxen as waiting to upload also.... it has something to do with Stanford's Servers.... Nothing we can do on our end.... just wait.... my boxen grabbed WUs, but didn't send.... the logs say they've tried a couple times... After the initial attempts, the client will try again every 6 hours (I think?)... so we just have to sit back and wait
Keep on Folding!! For the [H]orde!!
Alright, wanted to make sure it just wasn't me, almost all my boxes are using -advmethods, do they all come from the same server if they are configured that way or is there a group of -advmethods servers that hand out WU?
I have over 20 PCs running and not one of them has turned in a work unit in over 12 hours, it just happened, that's why I wanted to make sure it's not a problem on my end...
Edit: Logs are saying could not connect ot Work Server (171.64.122.138:8080). Then it's saying "Server does not have record of this unit. Will try again later." I imagine it's because it's can't hit the box it shows that response?
just turned on EM3 at work and yea...everything that had finished last night has a WU stuck in the que...luckily they were able to pick up another one and keep working tho :D
13 out of 14 working fine but with WU to send in.
Its the small point WU server that down so my PpD is up a little.
Luck .............. :D
If a server downtime benefits anyone, it would be you.
Pretty sure it's the -advmethods server, because all my clients run -advmethods, and it's happening to all of them, so I'm pretty much screwed until I can get around to the boxes.
Most of my boxen run with the -avdmethods flag.
Before that server went down I was getting mostly p77* and running at around 1.8k PpD.
Now its p2*** and its around 2.2k PpD acording to EMIII.
All boxen have work but still 13 WU to upload so I'm not changing any flags.
Maybe ..........
Luck............... :D
