Sleeving question
Stonejaw
Hey guys I am sleeving my new Antec TruBlue480W power supply and I have the universal molex remover tool but I dont have the 20Pin power connecter removal tool and dont really want to spend 20 bucks on one. Does anyone have any suggestions as to what else can be used to do this? Around the house items perhaps or some cheap thing. Also these Antec Trublues have the black molexes which are very hard plastic and dont like to bend or give at all which is frustrating me :) Any help would be awsome thanks!
Well, I took a solder-scraper that I had lying around to the grider and made one, basically is a thin, long, flat poker. I've heard that you can use a safety pin. They definitly aren't worth the $20 odd that they want for one, that's for sure
