Siren noise, no POST.
bob
My friends 7VT600P mainboard is giving him the wailing siren. No, its not beeping. Its a siren wailing.
Ive only come across the siren noise when you had a CPU fan unplugged, the threshold tenp in the bios was reached, or your voltage was way too low and set off another alarm.
He has all fans plugged in, has tried different combos of ram. I told him to unplug the computer, set the Cmos jumper to reset, plug it back in and turn it on and see how it goes.
Im thinking, totally dead mainboard. it does not even get to POST. No memcheck, nothing. He said the keyboard lights come on, and the fans come on.
Any ideas? Google is useless, all i get is junk about sound awareness and two-way radio noice cancellation.
I've heard mobo's make that kind of sound when no cpu is present. Perhaps the cpu is dead?
low power from the PSU
dead cpu/cpu not seated proper/overheated cpu
dead ram/ram installed backwards
short on MB
motherboard jumpers set wrong
AGP card not fully in socket--agp videocard had additional power plugs not installed
additional power plugs not installed on MB :eek:
it could be lots of things--go over the build part by part-- :cool:
also heard that kinda noice when the proc is overheating... check your HSF make sure its making contact to the chip but all the stuff above as well is a possibility
Make sure the heatsink fan in plugged into the CPU_FAN header too, sometimes boards wont post if they dont detect a spinning fan on that header.
So, that siren noise is useless, as an indicator. It could mean anything and everything... Wonderful.
What happened to the days of the morse code beeps? I liked those. Remember the beeps, look them up, fix the problem and be on your way.
I've gotten the french sirens when I forgot to turn on my water pump and the CPU was overheating. (Abit IC7)
Just for clarification, your motherboard is making it to POST, but its not passing because its detecting a problem. After checking http://bioscentral.com/beepcodes/awardbeep.htm, it appears that there is a CPU problem. If you have or can get your hands on a different CPU to try that would be a good idea. If a known good CPU fails with a heatsink properly installed and plugged into the CPU_1 header, then your motherboard is probably the culprit.
Hi/low, like a European police siren?
If so, that beep code is usually reserved for cpu problems with most bios manufacturers...
