Single 5870 + Eyefinity BFBC2 FPS?
thetruth
I have been looking everywhere for numbers on this. I am getting 3 20" Emachine lcds and have a single 5870 and a Q9450 at 3.6. Just can't find what settings, resolution, fps people get with this setup. I plan on upgrading next month when the refresh hits btw. Not doing crossfire unless it suddenly makes sense.
I got high 30's to low 50's with high settings and x2 AA on single 5850. Three 22" monitors.
20-40 on low settings with a Q6600 OC to 3.0Ghz at 5760x1200
20" is only 1680 x 1050? seems like you should get good FPS on that but I couldnt tell you what the typical bezel compensated resolution would be.
I am hoping to average 60. Might be a little too much to hope for though. I barely get that now at 1920x1200 medium settings, no aa, 16AF on DX11
My fps range would be 60 to 80fps most of the time at 5760x1200 with the following settings set in the ini file:
[Graphics]
Effects=medium
Soldiers=high
Vehicles=high
Overgrowth=high
Undergrowth=high
StaticObjects=high
Terrain=high
Shadows=low
Bloom=true
HSAO=false
MSAA=0
Water=high
MainQuality=custom
Texture=medium
DxVersion=10
Aniso=0
Detail=medium
RenderAheadLimit=2
Fov=75
You can barely get 60fps at 1920x1200 at medium settings on a 5870?? On my 5870 running at 900/1200 I can fully max out BC2 with 8xAA 16xAF DX11 and HBAO and average around 60fps.
then ill take a big hunch that your cpu limited since BFBC2 is a cpu core/clock monster or your running really old drivers..
that also goes piscian and his measly 3ghz overclock on his Q6600.. get that thing into the 3.4-3.6ghz range and you will see a nice boost in frame rate..
My cpu is at 3.6. I have the latest drivers and 4 gigs of sys mem. 64 bit Vista. I think I need to reformat.
The upcoming refresh isn't going to offer anything that beats a 5870. So you'll have to wait for the Caymen to hit the market for a 5870 beater, whenever that may be. Personally I won't be looking at upgrading my 2x 5870's until the 28nm cards come out.
This pretty well covers what the upcoming refresh will provide http://www.nordichardware.com/news/...d-6870-and-6850-launches-on-october-18th.html
As you probably know Eyefinity users can really benefit from 2GB, which cf provides but you can do your own homework in that regard. FYI, try this first http://hardforum.com/search.php?searchid=15560578
As I stated I'm running 2x 5870 and the following results are indicative of the performance that setup provides:
http://service.futuremark.com/compare?3dmv=2598920
Graphics Score 32313
Jane Nash 97.22 FPS
New Calico 91.99 FPS
FYI, I just ran across this deal @ Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16814150496R
None of those links work for me.
I just set everything to high and 4XAA and got about the same frame rate as medium and 1XAA. lol
I am sticking with a single card for now. I do not want to change mobos b/c i have a GIgabyte P-45 DS3L. Probably get a 2GB Caymen when it releases.
for competitive play, turn all settings to low, then i can average over 60fps all the time @ 3 * 24 inch 1920*1200 monitors. Still looks pretty good, all those effects and stuff just take away from killing others effectively :)
Only been messing with Eyefinity for a day or so, so more info as I get to play more maps and try higher settings, anyone else feel a bit naseous at first using Eyefinity, FPS games want to make me hurl, yes i'm using wider FOV for most things. Also profiles seem unreliable switching between Eyefinity and extended seems to break the monitor layout and i have redo them, any pointers appreciated. Really impressed with how much power a single 5870 has at high res, Dirt2 and F1-2010 really look great and NFS Shift was pretty awesome.
Well I reformatted, now all I have on my gaming pc is BFBC2 and that is it. Runs way faster now.More like 100-150fps Only issue is that the game is stuck on DX10. Changed it in my game settings doc and it shows dx = 11 but in game it says dx10. lol whatever.
