I have two offices that used to be connected via a point to point T1 but after researching the amount of traffic crossing it, I couldn't justify the cost for it and have turned it down. I'm now researching ways to reconnect the two offices, ideally spending as little (or no) money as possible.
To keep it simple and quick - at first I tried using Hamachi and NeoRouter but neither worked and it just seems like such a 'dirty' way to do it.
Thanks to killing the T1 I do have a couple of Netvanta 3200 Routers and it looks like Adtran may offer a 'enhancement suite' for the router that adds VPN capability to it. My only concern with using those is configuration.
I'm also wondering if I should simply take 2 old machines off the shelf and try something like Untangle to connect the two offices. My only concern, as I haven't touched untangle is configuration.
Would any of you guys mind chiming in on what you think a good solution would be
