hello
since my onboard intel sata controller is full (6x 2TB), i need to buy a raid controller card. I have space for 8 more disks in my tower.
I only need Raid 1, not even raid 10. Performance is not essential, but i don't want the controller to brake the disks performance. The disks are accessed mainly over gigabit ethernet. I use WD 2TB Green disks.
At the moment I have 2 PCI slots and 1 PCI express x4 (the long version; physically a x16 card fits) available.
Now I have two options:
1) buying a 8-port sata2 controller for the pci express slot.
With this solution i could go for a real hardware raid controller, since they are in the same price range as a 8-port fakeraid card like the highpoint 2320.
a) LSI MegaRaid 9211-8i
b) Adaptec Raid 2805
Unfortunately both are specified as x8 pci express cards. Since i only use raid 1, my x4 slot will certailny not be a bottleneck, but i'm not sure if both cards will actually work in a x4 slot. The LSI one should work, according to a few people on the net.. didn't find a lot of info about the adaptec one.
2) just buy 2 cheap 4-port PCI fakeraid cards for 50 euros each.
The WD green disks should be below the PCI bottleneck. But who knows, maybe in 2 years the 4TB drives will be a lot faster. And what about those fakeraid cards.. is it good enough for raid1? I don't mind if the cpu has to work a little bit, it's idling anyway
could someone help me with my choice?
thank you
thank you
