Robertmarcus
- Jun 4, 2012
Hi [H],
I have decided that my next case will be a Silverstone ft04, but i had some questions before i pull the trigger.
1. I saw in a review China that it had adapters if you wished to install 120mm fans for watercooling. Well, i do. I have a monsta rad sitting here, and i wanted to use it in this build. Tony or another owner, can you validate that it comes with adapters for 120mm fans?
2. Are all the HDD cages removable? I mean, all of them. As in, i want 0 hdd cages or anything in the front of the case.
3. What is the length from the front fans to the back of the motherboard?
4. How much room is there from the motherboard tray to the back panel, just so i can plan where to put my ssd.
Thanks Tony or any other owner,
-Robert
-Robert
