Vertigo Acid
2(-log[H+])4u
- May 31, 2003
Indeed, it would sound like it improperly calibrated. Have you done a two-point calibration with it lately?
good to decent PH meters use a glass or membrane cell to measure the pH and it is pretty accurate across a wide range of ion cncentrations.Lazaryn said:The only liquids that conduct electricity reasonably are liquid metals and water which contains dissolved ions. An electric current passes through an liquid with dissolved ions since ions are charged particles when they move from one electrode to the other. As someone said earlier the only ions in pure water are H3O+ and OH- and those are in very low concentrations so pure water does not conduct very well.
Can you please explain how the pH meter works. To me it looks like it measures the resistance of the water which will measure how ionised the water is, not it's pH as only the H3O+ ion should be measured for pH. Go down to the local swimming pool centre and buy some pH indicator, as the chemical on the indicator reacts to H3O+ and OH- ions it should give a more accurate pH reading.
Fuck if I know..Lazaryn said:Can you please explain how the pH meter works.
demons9872 said:why do u all think silver would be a waste yea its more than copper blocks but silver isnt worth alot go to your local pawn shops they will sell u scrap silver real cheap all u gotta do is melt it down and make your owne blocks i have around 2 ls of pure german silver from my pawn shop i might have paid $100 for it all thats enough to make 4 blocks so $25 and a few hours of my time for a silver block yea it sounds good to me
heh........it sometimes makes you head hurt, doesn't it?Cathar said:You know, you're quite right!
It really is easy to obtain commercial quantities of guaranteed 99.99% purity from the local pawn shop.
Danger Den should head down to their local store right away!
demons9872 said:silve scrap is 7 bucks a ounce any of u who r gonna try and fight me on this are gonna loose
Top Nurse said:Hmm.. So are you saying that those blocks that Aqua Computer sells for $150-200 USD made of .925 Sterling Silver is a waste of time? IOW, there is nothing but the bling factor?
