Silent fans?
Dapperdan
I need make some of my pcs silent, what ones are and where can I get good but silent fans?
www.silentpcreview.com
probably the best site on silencing your pc.
i personally use 80mm Nexus Real Silent fans and 120mm Yate Loons @ 7v.
you can order these from Frozencpu, SVC, Case-Mod, Performance PCs, jab-tech.
if you want to make your pc silent, i think youll have to replace more than case fans. you should consider silencing your CPU, Video Card, chipset cooler, PSU, HDD, then worry about the case fans.
I have a Shuttle SK41G and I am sure its the CPU fan that needs replacing but I might as well replace the fan on the geforce 4 to...no clue how to do that
i also have a Shuttle XPC!! i love these little buggers. had to do various mods on mine to silence it also.
