Sil 3114 SATARaid boot problem...
ShogunCS
Hey guys, I've never had any trouble using SATA or RAID for that matter but ever since I've had my DFI Lanparty B mobo I just can't get my 36gb Raptor to boot or even detect in Win XP (have XP installed on an IDE hdd). Anyways, the problem I'm getting is that whenever I select SATA or SATARaid to be enabled on boot up (in the Genie part of the BIOS config settings) My computer hangs at this screen:
"Sil 3114 SATARaid BIOS Version 5.0.35
Copyrght (C) 1997-2004 Silicon Image, Inc.
Press <Ctrl-S> or F4 to enter RAID utility"
And it hangs at that screen indefinately and I can't get it to work no matter what! I've tried setting the BIOS settings to boot of IDE and a few other things which don't work. I'm not sure what to try on this. I emailed DFI with my problem and their english isn't to great but what I gathered from them was a defective SATA controller. I would like to try somethings to get it to work before I RMA the board! Thanks in advance guys.
You need to disable the Sata RAID Boot Rom in the bios. I have this same board, at the default the board tries to raid the sata drives, since you only have a single SATA drive you need to keep it from using the Raid. It can also be the reason why your system hangs when you try to enter the raid utility.
I've tried that setting before to no avail... still the same "hang" problem as before.
Mine did this when I had the RAID drivers installed, but no array. Try uninstalling the RAID drivers so it won't even try to use them. Mine was the Infinity, but there should be no difference.
Yeah I've tried different BIOSes and I've also tried formatting and not installing the RAID drivers with the same effect. I might just have to buy a SATA controller card because I'm starting to think the onboard SATA could be corrupt somehow.
