Signature help
Liver
I'm trying to link my heat in my signature.
I've tried the heat but I can't get that to work in my signature slot. Instead it always shows as it does below.
Thanks.
Links are not allowed in sigs. That function is disabled.
That explains that! Thanks, was wondering if there was something I was doing wrong.
Would you say my sig has the best way to link my heat? Or would you suggest another method?
If you are posting in FS/T it's okay to put a link to your heat in your post if it's relevant. Otherwise, anyone who wants to see it can just copy/paste from your sig. :)
Just post your Heat handle in your sig (like I did). It's easy enough for someone to look it up in the Heat directory. :)
