Side Panel Cutting
fantomau
If I was to buy a TJ07 case and AC Ryan UV Blue Acrylic to replace to side window, Is there anyone who could cut it to size and drill the screw-holes and how much would it cost?
I'd do it myself, But I cant I have CTS and my hands shake at times.
I'd be happy to do it for you provided you pay for shipping to Canada and back.
The *only* concern that I have is that the stock window is mounted on the *outside* of the case, which would be very difficult to do properly. If you don't mind the window mounted on the inside of the case, It would take me all of about 10m to do.
Because it's much harder to cut the window with rounded edges and have them all look roughly the same.
Additionally, the sides would have to be polished perfectly without marring any portion of it.
Plus, you have to cut the acrylic perfectly, which, without the aid of a laser, CNC or water cutting table, you're kinda banking on god's grace.
