Shuttle Takes SFF to Another Level
Terry Olaes
I Used to be the [H] News Guy
Shuttle has long been synonymous with small-form-factor PCs and now it looks like they’re taking it to another level. Powered by Intel’s Atom, Shuttle’s X27 will use 23W when idle and 36W when active. September is the scheduled launch window for the US.
Edit: Found a page with specs.
I'll be more interested if the box had the power to play true HD content.
Now I'm wondering if Apple and other manufacturers will jump on the Atom bandwagon and stop spitting out these micro-PCs like this one and the Mac mini, just retooled maybe even smaller. Guess time will tell...
I'd like to see a size comparison between this and the X100 they released some time ago. If it's half the size, I'll be impressed but otherwise the expandability of the X100 wins out.
For a pc that size I think the via nano would be a much better choice. Sure it'll chomp down 10-15 more watts, but it's really not that big of a deal for a plug-in pc even if it is rediculiously small and the extra processing power easily makes up for that.
only if exposed to the 4th dimension. I was thinking of using these maybe as a DVR, since the mass use of USB devices. I believe apogee makes usb video cards.
I haven't seen them from apogee after 2m googling, but eVGA has one that can do 1600x1200x32bit with lossless compression across the USB link.
Depends what the processor is. The nano will spank an atom based one, but a system with a core duo/core2 duo ULV chip will be almost as low power and beat the nano just as hard.
Oh wow, very nice. If they manage to put a GPU in there that can handle HD as well as HDMI and optical outputs, and you've got a very cool little HD HTPC there.
