Shuttle SG01
The Equalizer
Hello I'm interested in building a one of these, please advice me on any of my components what I should/shouldn't get, and whether it will work and be free from heat and space trouble etc.
Antec NeoPower NeoHE 550 550W Power Supply
Intel Pentium D 930 800MHz FSB LGA 775 Dual Core Processor
Evercool AL6010 60mm Ball Aluminum Cooling Fan
SilverStone SFF Cross Flow Fan (SST-FX121) for Silverstone SST-SG01
Intel BOXD925XBCLK Micro ATX Intel Motherboard
OCZ Gold Series 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Dual Channel Kit System Memory
Western Digital Caviar SE16 320GB 3.5" SATA 3.0Gb/s Hard Drive x2
eVGA Geforce 6800GS 256-P2-N391-AX Video Card(will be 7900GTX when available)
NEC Black IDE/ATAPI DVD Burner Model ND-3550A
SilverStone SST-SG01-BE (Evolution Model)
Let me know if those components will work, or any advice on what would be good let me know, much appreciated.
Looks good excepet for one problem. You mobo will not work with your processor. A dual core intel requiers a 945, 955, or 975 chipset. The best matx mobo for intel is the ASUS P5Dl2-VM ir has great overclocking options to push that itel even further. The only downside is that it dosen't have firewire.
LInk to Mobo:
http://www.asus.com/products4.aspx?l1=3&l2=11&l3=194&model=536&modelmenu=1
Another suggestions is you don't say what speed you mem. is using. With dual core and the new chipsets they support DDR2 667. This would be the best speed to get, for the extra mem. bandwith, but also for the overclocking headroom.
Thanks for the advice, you're right that motherboard won't allow the processor I want, good spot. The memory is ddr2 667 so should be suitable, also do you know of an Intel motherboard that supports dual core, not just intel based but an actual intel brand motherboard? Besides that and the change from the 60mm to 80mm fan, do you think everything else will work ok?
This motherboard has onboard video memory, does that mean I can't add an nvidia orf ati graphics card? How does it work with onboard video memory, can it be disabled?
Intel BOXD945GTPLR Micro ATX Intel Motherboard
Any motherboard that has the 945G chipset has built in graphics. But they also allow you to have a regular PCi-Express video card. To turn off the internal video, just go into the bios and where it says onboard vga, switch it from enable to disable. It will then just use the ATI or Nvidia video card you have installed, its better to use a external video card because the onboard vga hurts system performance
As for your suggested Intel motherboard you want to use it will work just fine.
Just one more question? Why would you want to use the intel motherboard?
They are more expensive, and offer less features than other companys.
Here's a list to Newegg that shows M-Atx boards that work with Dual Core and use intel chipsets.
http://www.newegg.com/Product/Produ...&ATTR21=&ATTR22=&ATTR23=2010200280+1075707619
Here's Asus motherboard that has better features and is cheaper. The only thing it does not have is ICH7R chipset it has the ICH7 chipset.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131545
