Shuttle sb61g2 question
Firebomb
yea i have a new shutle with a 2.6c in it and i am trying to find out that my mhz is in the boot screen instead of going all the way to windows to do it
when i but it up all it has is a BIG intell inside HT icon on there that blocks everything while it boots up any ideas how to get that off of there?
and i need to find out what bios rev i have..
can anyone give any Ideas??
thanks
You hit delete a few times while it is first powering up, and it will go into the BIOS. You can turn the logo off, and see a traditional POST screen. Your manual will better explain the name of the option and where to find it.
i did that, a few times even the only thing in the bios that talks about a icon image is disabled and i still dont see anything
i dont understnad it i want to know if anyone else has the shuttle and if it shows up on theres
thanks
thanks
I have a Shuttle...SB51GB...and that's exactly how I disabled it. Read in the manual...it clearly explained it for mine.
I have the Sb61g2 the 800mhz Intel one,
I dont see anything about that in there it has a show small logo disable or enable it dont change anything
i am not a noob at building comps :) i wouldnt miss a little thing like that but i am new to the shuttle as this is my 2nd one i had the ss51g before.
but i cant seem to get logo of the intel inside image off there
