shuttle sb61g2 problem
Firebomb
yea i have a new shutle with a 2.6c in it and i am trying to find out that my mhz is in the boot screen instead of going all the way to windows to do it
when i but it up all it has is a BIG intell inside HT icon on there that blocks everything while it boots up any ideas how to get that off of there?
and i need to find out what bios rev i have..
thanks
trying to find the section to do it then, then i said ok lets try here..
LOL
where should i go?
Originally posted by Firebomb
where should i go?
Hell.
General Hardware?
Motherboards?
Strictly Intel?
Overclocking & Cooling?
SFFTech.com's forums?
Or, how about you listen to what I told you on Trillian 4 hours before you posted this and accept that it always shows the HT P4 logo. your 61G2 does this. My 61G2 did that. my 65G2 does this.
Besides, your P4C is weak, it doesn't OC. you don't want to be reminded of it's inferiority :p
I can get away with mocking him since we're friends IRL
arg what a bunch of punks!
I got the same machine all you do is it hit TAB and you'll see it providing your monitor warms up fast enough.
shh! you're helping him!
I think he was wanting a permanent fix though...but, yeah, Tab usually hides the cosmetic image...although I've not done it with this system...as it's always on.
go into your bios and take off the option intel branding. thats what it's named on my mother bored it takes away that picture in the beginning. it might be named diffrent for u just look around.
thanks
lmao....
