Shuttle Questions
fenton06
I am putting a system together for a friend, and will be utilizing the Pentium D805, because it is so cheap. I would also like to overclock it a little. The question is, what Shuttle system do I put it in? The 805 says it is a 533 MHz FSB, but all the shuttle models I look at are 800/1066. I am assuming it will work, becasue it should be backwards complatible, but didn't want to take the chance. Any input?
Edit: how does this look?
http://www.newegg.com/Product/Product.asp?item=N82E16856101486#DetailSpecs
the case seems like overkill for a 533 fsb CPU. There are 533/800 shuttle models on newegg, but i'm not sure if any of them are good
