Shuttle Cases
Cirue
Are there any places that sell shuttle Cases (preferably the Black XPC G2 Case) Alone? meaning not including the motherboard? I want the case but it costs too much to buy the barebones. If you guys have any sites or anything let me know. Fry's sells only the Fudin case and it doesn't fit my style.
Originally posted by pHatalbOom
Lian-Li makes 2.
that's not a shuttle case. They are for mini-itx motherboards... The only way to get a shuttle case is to buy a"barebones" but it's not really a barebones, since the only mobo's you can easily get that will fit into the case are shuttle's... and the power supply is also a specially sized one, that you will be hard pressed to find elsewhere... I don't know what good a shuttle case would be without a shuttle mainboard that is designed to fit, and a powersupply that is also designed to fit.
