Shuttle AN35N-Ultra
ChingChang
Is this a reliable motherboard for a budget system using an XP 2500+? Real nice price ($55), but will it be any slower than using a higher end board? if so I think I will go with a better board, but do motherboards affect speed at all?
I was also planning on putting 2 sticks of 512mb PC3200 corsair RAM in dual channel. I would get PC2700, but the Corsair ram only costs around $90 each. Has Corsair ever had any compatability problems with Shuttle?
Have several, most excellent motherboard.
Plus good overclocking options. :p
The Corsair will be fine. Personally I have Kingmax PC3200 and PC3500 in my AN35N boards.
It's a nice board and just as fast as any other using that chipset. The primary difference between the AN35N U and other boards is the no-frills nature of the Shuttle in terms of features. Overclocking capabilities are very good, particularly with added cooling to the north/south bridges.
they are most excellent, we sell mostly that model of board at work, in the last year, ive had 3 die (out of 300) out of those 3, all 3 were installed by the customer, one mounted right to the case and the back was scratched to shit, the other had a screwdriver slip, 3rd died due to the customer using his cheap deer psu saying its worked great for him. i swear by shuttle ive personally used their boards many years ago in my own systems, never had a problem.
Its a good board. My motherboard died awhile back on my extra parts computer. It was a cheap replacement. I now use that computer as my FreeBSD firewall box. Runs 24/7 with corsair ram and have not had any problems.
Do these boards really have only a passive heatsink on the northbridge as the picture at Newegg shows? I only find it weird because their mATX version has active cooling. Heh, that little mATX has dual VGA on it too! Funny.
@ Pecos...Well as you said, the microATX also has the IGP in the northbridge. This makes a big difference. Yes they are passive which is just fine. I took off the heatsink and replaces the pink pad with some white goop though.
@ ChingChang... I hope you like it. :)
It does have the passive cooling on the NB. If you want to hit FSB speeds over 220 or so, it's a good idea to mount a small fan on there, and be sure to slap a heatsink on the South Bridge.
