Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am running XP and when I go to shut down, my comp restarts. It turns on and hibernates just fine. I built it myself, is it something wrong with the wires or the software? How can I fix it?
I ran into this problem after installing a no-name PCI wireless card and I solved it by going to system properties and turning off "reboot upon service failure" or something like that
My computer->properties->advanced->startup and recovery->system failure restart
Check your power on-led umper configs. I had the problem and I took some time ot look at those--apparently, I had some of the on/of jumpers done backwards....switcheing them around not only gave me the ability to turn things off, it gave me an LED on the case light that I didn't even know was there.
The windows settings option is great. A friend of mine had hte no-name PCI card problem as well.
Older versions of Roxio's burning software can also cause WinXP to not shut down properly (causing a reboot). There will be a quick BSOD just before it does this.
