HDMI will be connected to a TV. Otherwise, I would get a set of small computer speakers to connect using either USB or motherboard audio.depends on what youre connecting to. desktop speakers that are self powered, use onboard. going to an avr, use the hdmi.
get something like these that has both and see which you preferHDMI will be connected to a TV. Otherwise, I would get a set of small computer speakers to connect using either USB or motherboard audio.
Whatever works until you get your system to the point where the sound quality is an issue.I mostly play single player games. I don't use headphones at all, and don't think I care about 3D audio.
Whatever you're happy with using ^_^I mostly play single player games. I don't use headphones at all, and don't think I care about 3D audio.
