Should I upgrade my Old (sorta) Rig?
HomerRulez
Basically what Im asking is, What Mainboard would be better to have than the gigabyte down in the list. Overclocking is def. in the near future of what the system will be doing. I've looked at a few but not sure what to do. I like the EVGA Classified but cant decide on one of those (not going to water cool in anyway) or the Asus P6t deluxe V2 I believe it is. Are those the best performance and stability wise? I dont want to over clock and have it be unstable. I plan on buying a good cpu cooler so that it wont get too hot.
I've got the following
i7 920
2gb ddr3 1333 ram
32gb ssd sandisk
750gb seagate
250gb seagate
Gigabyte x58 Extreme
4870x2
Thermaltake toughpower 1000watts modular
Antec 900 case
Basically was looking to get a better mainboard, video card, Ram and Case.
What I use this PC for is Gaming, Watch Movies (bluray/dvd) and Adobe editing (video/picture).
Depending on what games you play, As for the Adobe editing, are you referring to Photoshop? If so, that's more of a Monitor choice than Video card (not to say Video Card isn't important as well).
adobe encore, after effects, photoshop, primere pro are the usuals I use. I play at 1920x1080 res for my games. Crysis, COD: MW2, stalker, company of heroes. MW2 the most though but still I like to play as high a settings as I can get.
I would say purely from performance standpoint, you will see some improvement by upgrading to a 5850/5870/5970 and you'll have DX11 support. I would check out some better ram too, I really am pleased with my 6gb g.skill trident 2000 kit and it did not break the bank!
i don't think is nothing wrong with your mobo unless you want to OC you cpu if thats the reason then well a Asus P6T or the evga x58 will do just fine
From what I looked at.. ain't nothing wrong with the Gigabyte board unless you want to spend a few hundred more dollars to get MAYBE 5mhz more base clock. :rolleyes:
Put a Prolimatech Megahalems on your CPU and you should be able to overclock a bit better. A lot of overclocking is heat limited. Also just pull out that 2Gb of ram and buy a decent 6GB DDR3 kit and you should be good to go.
Can you describe what problems you are having with overclocking? what have you attempted thus far? overclocking requires a lot of tweaking and changing of voltages and memory speeds to work right.
newegg is currently selling 2 m/b's with new Marvell chipset that supports SATA 6 Gb/s and USB 3.0. One is an Asus the other a Gigabyte
The fact that OP said "old rig" in the title referring to an i7 build made my system cry a little...:(
I bought this system and did not build it myself. I got the entire unit for $900 about 4 or so months ago. I think I posted about it here. I cant even remember how long it was really. Maybe I can pull the date. Anyways since then I just had a bad feel to it. Things dont load the way they did when I had an e6600, q6600 and a q8200. My system was nice and smooth with fast loads on vista. Now it seems slower, doesnt load up as fast and a few other things. The feel of ones computer for some is more important in some aspects than what the numbers say. Im using an elitebook HP notebook 8000 series and it just is a lot smoother. Its just odd. I figure maybe its all in my head but the difference of a nice new system would mean no more than $500 plus I literally hate the inside of my antec 900 case. Despise it. You never know how its going to be going from full tower to mid tower until you realize that the best cable management in the world couldnt save you from tight spaces. I've got the funds and with a nice bonus coming soon, I can spare it no problems. Plus Im sure with buy new egg instead of craigslist this time, that warranty wont be an issue. While I have never needed to warranty anything, Im still afraid of the old "show me that receipt" policy.
I'm with Tbird87 on this. I would just throw some ram into it...I noticed a hefty difference on my Q6600 when I went from 2 gigs of mediocre ram to 4 gigs of good ram...
As many others have said, you have a pretty high end there and the only thing that looks out of place is the memory. You should bump that up and maybe get some faster ram if you intend to OC it later.
The difference between DDR3 1333 and 1600 is pretty negligible in real world performance. The only reason you should buy 1600 is to run 1:1 CPU:RAM when OCing. It really makes little sense to throw out the ram he does have.
His problem is that he only has either 2x1gb in dual channel, or 1x2gb in single channel. Either way, he has way too little ram, and is not running triple channel. He either needs another 1gb stick of 1333 or another two 2gb sticks, depending on the config.
My advice to the OP: Your mobo and vid are perfectly fine, but you can upgrade to a 5870 if you want. Cases are a matter of personal preference, so getting a new one is up to you. Just get more ram, and make sure you run triple channel.
More RAM for sure. Otherwise, how can you say this system is "old" already... it's only a year "old."
