I had weird problem last night, out of no where my ethernet and audio ports stopped working I tried rebooting it and that fixed the problem but should I worry about this further or was it just a fluke? My specs are in my sig.
It was the probably the issue unique to that situation, maybe some crash happen. If it occurs more often than you should first try to reinstall system and drivers and if not than probably mainboard problem, bios update maybe helpful for this too.
I would advise this is something to be aware of, in my exp. this generally indicates possible issues with motherboard generally due to overclocking. It could be the continued overclocking on the board could be causing a failure to the board and the ethernet and audio are sensitive to it. Additionally if you have your pci -e bus with an overclock this may be affecting it as well. Otherwise it could have just been an out of left field issue.
