Well, it's that time again... for me to go into my PC and mess with what was already working, that is. Here's what happened, you guys tell me if I should be worried.
I had a Rosewill case, which sucked, so I got a Cooler Master case, which doesn't. Now, in the process, I figured, I might have to re-seat my cpu heatsink (Arctic Cooling Freezer 7 Pro) so I got some Arctic Silver 5. (I was using the cooler's pre-applied goop at the time) Anyway, I got the case in and said, what the hey, let's just apply this silver stuff since everyone seems to agree that it works pretty good. Well, here's where things get kinda funny.
When I first applied the stuff, I gobbed on what I thought was sufficient coverage. (after cleaning off the old goop of course) I turned on my machine, fired up Core Temp, and WHOA! It says it's IDLING at 49-51c! I must be doing something wrong, I thought. So I unplugged the rig, opened it back up and removed the heatsink. After seeing what showed up, I realized that it was definietly too much. It's spilling all out to the side and STILL left a decent layer in between the CPU and the heatsink. So I grabbed an old credit card and scraped some off. Left a really (less than paper) thin layer on each the heatsink and the core. Put it all back together, and fired it up again. Fired up Core Temp, and... ARRGH!! it's idling at 51-53c! What the heck happened? I thought. How did it get worst? So there I go again, taking it apart, this time I completely cleaned off the old stuff (with isopropyl) and reapplied a new layer on the heatsink only, since it was easier to handle, fired it back up, and now we're at 48-50c.... grrr... Alright, I said to myself, let's see what happens under load. Up goes Prime95, we're at about 57 fairly quickly... alright, let's try a game, so up goes Far Cry, ('m kinda late to that party, I know) I played for a while, like an hour, jumped back out of the the game, Core Temp was already running and I see it's sitting at 63... okay, so at least the idle/load differential makes sense.
Here's the REAL question (never thought I'd get to it, did ya?) I've set my cpu warning temp in the bios to 60c, yes, 60c, and it NEVER BEEPED during Prime95 or Far Cry. So going back to the original question... should I be worried? My case doesn't have very good ventilation (on purpose, for noise and dust concerns) so I figured it was going to be a little warm, but 50c idle is a little harrowing. Is Core Temp reliable? Unfortunately, I don't really have a 'before' number to compare with. I know that it USED to idle at 40c in the old case, but that was before I started closing up vents and disconnecting fans, I don't have a number for after that. Now in the BIOS it IS idling at about 39-40, but I figured that that was going to be low only because it's the processor's least active state.
By the way, it might seem like I'm new at this, but I'm really not, honest. I've been applying goop to processors since the Athlon Thunderbird days, I'm just a little out of practice. (obviously)
If you read all the way through that junk, thanks! And thanks ahead of time to anyone who replies!
Art
Art
