Wolf, I wont say Sharp 32" games better than my Dell 30" (which can go to higher 2560x1600 rez).ZAK -- Does the Sharp "game" better than the Dell 3007, despite the Dell's higher resolution?
Z3r0, I'm a total noob for calibrating. Did you say you have a Calibrating disk?Picked one up at Sears today. LOVE it.
Using it for my PC and 360.
I'm only 2.5' or so away at max so it SDEs badly,....
the only thing that's driving me nuts is calibrating ....
Matt, use the Settings that your eyes like,Am I only only one that jacks the Color all the way up to 20+ with this display?
Nojoka, welcome. BTW, read the whole page in that Thread. When you do, you'll see that a tekky-guy "rm88" replied to the guy who posted that image.Pixels are staggered?
This image was posted in this thread on the GP1 which has the same lcd panel i think:
http://www.avsforum.com/avs-vb/showthread.php?p=12584652&posted=1#post12584652
Anyone with one of these find this bothersome? I have one ordered for pickup but it hasn't come in yet.
Thr only "caution" I ever heard was:
"Dont keep Backlight Setting at maximum, cuz it'll shorten the life of the backlight-bulbs
Dunno if its true, but I pass it on.
Z3, thanx for input.Obviously it will lower the life, but how much is the question. There's also a large difference in power use, but I can't remember how much. I just set my backlight from +9 to 0 (STD) for those reasons, especially since I leave it on all day every day as a PC display. Easier on the eyes as well, +9 is damn bright!
Also, what did "SDEs badly" mean?
I found this post: Sharp settings that work for me".
Apparently some guy had two different calbrating Disks and gave settings for each disk. (Does Newegg sell Calibration disks?) .....
Using DVE to calibrate:
Backlight -3
Contrast +35
Brightness -12
Color -7
Tint -3
Sharpness -4
User Mode > Advanced
ColorTemp Middle
Black On
In Options, turn Digital Noise Reduction to Low
Using AVIA to calibrate:
Backlight -3
Contrast +35
Brightness -12
Color -5
Tint -3
Sharpness -4
Color Temp Middle
Black On
Also, a Techy-type guy, posted this Notice.....
The name "Brightness" is misleading, its a poor choice of words.
The Brightness control does not set Brightness level-----it sets BLACK level".
Hope these settings help someone. Cheers.....
Also, i am sure if u try 3 backgrounds....white, black, blue.....u will see multiple dead pixels.
Sorry to hear you hit a bad streak of luck.Also, i am sure if u try 3 backgrounds....white, black, blue.....u will see multiple dead pixels.
Mr.Scarface,
I must be lucky... I've been back and forth a few times over this screen with various coloured backgrounds and can't find a single dead or stuck pixel.
Now as for using this screen as a PC monitor, it's actually quite good - but you need to spend the time and set it up properly. One of the key settings is the "sharpness" level. Anything above -6 and I find you really start to loose on screen detail. I'm currently using -8 and sit about 3ft. from the screen.
For watching hi-def movies I'll often set the sharpness to 0 or even +2 if the video quality is "soft". I watch movies from a distance of about 6ft. to the screen.
sharpness -6 eh? I can't really tell a difference between 0 and -6 but I haven't tested much. On the desktop however, -6 starts turning text to mush. It's kind of like taking your glasses off.
Anyone heard any new info on Sharp's new 32" GP3U ?
Its supposed to be replacement for our nice 32" GP1U ---- and has many new "bells n' whistles".
If you hear any facts, rumors, plz post here? (Allegedly, we might see it at CES show this January).
I should get my GP3U on this coming Friday. The waiting and anticipation is killing me.
I'll do a brief review of it after I get it.
Of course if you adjust from 0 down to -6 then yes it will look quite blurry. Best thing to do is to adjust the setting then go do something else for a bit then come back to the screen. 0 is too sharp for PC use unless you are sitting a good distance away from the screen. I find images, graphics and text to look better on the Sharp with a slight softness. Too sharp and everything looks etched and distorted.
My eyes aren't yours though so ultimately set it up they way you like![]()
