Originally posted by Nybbles
Nope, not gonna happen.
There are networked scanners, but they are part of large networked copier systems.
Originally posted by RavinDJ
Can't you do Remote Desktop or PC Anywhere through the network? And then just log into the host machine, the one w/ the USB scanner, and then just scan and send the files else where. Right?
Not exactly what the original post had requested, but eh... it's a semi-solution...
Originally posted by BGM
why is very easy..
i have a multifunction printer at home on the network. In order to get use from the scanner it has to be connected to a computer, so that computer has to be turned on, the problem is that when i want to scan something onto my computer which is in another room, i have to log into the server actually sit at it and scan it in, then send it to myself accross the network, its really irritating!
if there is software that can share scanners accross a network, id love to hear it!!
