SFFS with a handle
SilverStone will be releasing the FraggBox2 case after New Years. Also, the CFI cases have handles, I think.
My Hornet Pro SFF has a nice carrying handle. It's mounted below the optical and card reader drives.
You can't just screw one in? Shoot, when I get my Shuttle that's what I plan to do. Plus, it allows you the option of picking any handle you like in the hardware store, heh, as I'm sure any one would do, no?
-rye
I ended up getting this case
AMS eCube EG65
I got a decent deal on it.
I put in a 2.4 northwood, DVD burner, 200gb hd, 512mb of Corsair memory, video card, tv tuner.
All I wanted was a "cheap" spare system I can take when I choose. When it is at home, I just use it as a tivo.
OK, now you've gotta mod it. My friend has one of those and put a 120mm fan in one side panel and drilled all these little holes in the other panel. With the exhaust fan, you can actually feel the air being forcefully sucked in through the holes. The breeze goes right over his graphics card. His system runs cold as the antarctic now.
I was thinking about putting a clear 80mm blue fan on the right side. I can't do one on the left because it would hit my video card.
I also have to dremel out the built in fan grill.
I have that same ecube in black. It looks awesome. I too put an 80mm blue fan on the side. I dont have it anymore because i ended up putting a zalman fan there with my rad in my watercooling setup. Here is a pic of how it used to look.
