makavelli302
- May 1, 2011
Okay guys,
I'm in the process of researching SFF rigs. The goal is to build a secondary pc for my lan rig. I'd like to use the fractal Design Core 1000 case, but im open to other options that size or smaller. I know its a pretty crammed case but I'm looking into two cooling options. A custom water loop with a dual or single bay pump/reseviour combo. or using an "all in one" H60 or H70. I'll be running a 2500k over clocked if possible up to 4.8 paired with the asus maxims Matx (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131759). I have a few questions
1) has anyone ran an all internal water loop with one of these cases
2) recommendation for any other case options?
Any and all help is greatly appreciated, the goal is to have the smallest size case that can fit an matx & full size graphics card.
