I talked to YeOlde a little today and have been throwing around ideas back and forth.
I have 2 clients that are badly in need of upgrades.
Client1 - big construction client, server crashed this week and we are working on getting most of the data back and got then running temporarily. I just ordered them a Dell 2950 III (2 x Quad Core Xeon 2.66, 4GB DDR, 2 74gb 15k sas drives in raid 1, 6 146gb 10k sas in raid 5) running SBS 08 but was originally going to downgrade to SBS 03.
They currently have a 2nd Server 03 box running Timerbline/BES (Xeon 3ghz, 3.5gb, raid something). Office size is about 6 people in office and maybe 6 field guys. When we first picked them up from the previous tech they mentiond how remote access has always been a shady spot. We discussed Terminal Services which would make the most sense for the "field" guys.
So our original estimate was new SBS box, new TS box, and keep there current Timberline box.
Now I am feeling that I should load Timberline on the new SBS box (after adding memory), and getting new Dell box for TS. Would it make sense to consolidate or just keep the 3 machines going? The client has the money and doesn't care if he has to spend I just want the most reliable and fastest setup for him. (COULD USE OLD SERVER AS UNTANGLE, SINCE CURRENT SONICWALL IS SO SHITTY)
Okay..........
Client 2 - Marina with 2 locations. About 10 users on each side. They currently have a Server 03 machine with a Xeon 1.8Ghz and 1GB running Domain, DNS, DHCP, File/Print and Dockmaster and Peachtree. Offices are connected through Business Cable (at max 30/10) and Freedom9 Freeguard on each side IPSEC VPN. So Dockmaster is the main program which everyone uses. Peachtree is used by 2 girls (1 on the local server side, 1 on remote side who is the primary user). Everything works fine but they want to move to Exchange, and have mentioned that opening some files has been slow (haven't heard complaint in a while). Use to be on T1.
So after talking with YeOlde today he gave me the idea of specing out a nice SBS 08 (similar to above in tower form) box loading up Dockmaster on it and keep the setup the same. We would then have the Old Server which we could use as a Secondary Domain, DNS, DHCP and Peachtree Server at the second office.
I then also had the idea of loading everything up on the main server, and making the original server after memory upgrades, a Terminal Service box and having the remote side connect to that.
Ideas?
Thanks,
Dan
Okay..........
Ideas?
Thanks,
Dan
