Okay, forget whether it's useful or not. I personal never do because I don't see the point, when I can just as easily set the hard drives as a master and a slave.
Okay, here's the question that needs an answer. Another member, who will remain nameless to avoid embarassment, says to me that if your using an older 40 pin IDE cable...ATA33 and down...that you cannot use cable select for hard drives. Now I find this to be absolutely wrong, as I've used cable select back in those days to get to misbehaving HDDs from two different brands to work together. So tell me honestly...can you use an ATA33 40 pin cable and set your drives to cable select? I've done it...but that's not good enough for this guy. Please post if it's possible, and if you've done it.
