- Jun 11, 2003
First off... Im a linux noob for the most part. Im familiar with linux but by no means a linux power user.
I installed LinuxMint onto the thumb drive with Universal USB Installer and gave it 4gb of persistant storage space. It seems to be significantly slower then if I just create and use a live thumb drive.
Some things dont seem to be working like they would with a normal live usb drive as Ive messed around a bit with them. Updates for instance error out asking me to do something with apt-cdrom command. A normal live cd works perfectly fine with updates.
Also, when I edit fstab in the persistent usb drive it does not save and update. It reverts back after I restart the computer.
If I want to run my OS for Snapraid from a USB drive what do you recommend I do and start with? Any tutorials you guys can point me to?
